R128 模组
针对 R128 芯片,百问科技提供推出了一种型号模块,如下表所示
型号SoCCPU0CPU1DSPSRAMLS-PSRAMHS-PSRAMFlashDAC
R128-S2-N16R16R128-S2Arm Cortex-M33C906 RISC-VHIFI5 DSP1MByte8Mbyte8Mbyte16M NOR Flash2 Audio DAC
LINEOUTLP/N
LINEOUTRP/N
R128-S3-ND128R32R128-S3Arm Cortex-M33C906 RISC-VHIFI5 DSP1MByte\32Mbyte128M NAND Flash1 Audio DAC
LINEOUTLP/N
详细参数​
  • XuanTie 64Bit RISC-V [GCV] C906 CPU, Support Vector 0.7
  • Arm M33 Star MCU
  • HiFi5 Audio DSP Xtensa LX7
  • 1MB SRAM
  • 8MB SiP OSPI HS_PSRAM@800MHz
  • 8MB SiP OSPI LS_PSRAM@AHB Clock with DMA
  • 16MB SiP QSPI NOR
  • RGB666, i8080, BT656, SPI Display up to 1024x768@60fps
  • G2D 2D graphics acceleration
  • DVP up to 1920x1088, JPEG encoding 1920x1088, 1024x768@40fps
  • 3 Audio ADC, 24Bit, 8kHz-96kHz, Support 4 DMICs
  • 2 Audio DAC, 24Bit, 8kHz-384kHZ
  • USB2.0 OTG
  • 3 * UART, 2 * SPI, 2 * TWI, 8 * PWM, 1 * 12Bit 10 Channels ADC
  • IR TX/RX, LEDC up to 1024 * WS2812
  • ISO 7816 Card Reader
  • Wi-Fi Compatible with IEEE 802.11 b/g/n 2.4GHz
  • Bluetooth 5.0 Dual Mode complies with V2.1/4.0/4.2/5.0, Support BR/EDR
  • 25.5*18mm, IPEX ANT, ESP32-S3 Compatible Pinout
资源下载​
购买链接​
引脚图​
高清引脚图:R128-S2-N16R16_PINOUT.svg
